Leasing PV System in South Florida, need advice please!
Re: Leasing PV System in South Florida, need advice please!
I hear you! Working on replacing a 14 year old 10 seer Lenox 2.5 ton AC in Jan. with a Trane 3 ton 17 seer 2 speed heat pump. Should cut the load there by at least 50% over the old Lenox.
Wondering if radiant barrier in the AZ attic might not help too. -
Re: Leasing PV System in South Florida, need advice please!solar_dave wrote: »Wondering if radiant barrier in the AZ attic might not help too.
Solar_Dave, looks like your roof is already shaded with solar panels.
Joking aside radiant barrier helps a lot with shingles, With a tile roof not as much, I guess the tiles already have an air gap to roof. -
Re: Leasing PV System in South Florida, need advice please!Solar Guppy wrote: »The foam is good, but I'd still have R40 to isolate the living space ceilings from the attic
And yes, conservation is fun and very cost effective!
I will get an estimate to blow in fiberglass insulation over my existing batts, it would have to help the current 20 year old batts -
November usage bill arrived $121.97
33 Days averaging 34 KWH per day = 1124 total kwh
It has never been this low.
Cooler Day & Night temperatures and consistent Solar Water Heating, Only needed to turn on Electric Water Heater for one tank full. This after 2 cloudy/rainy days.
We realize how seasonal the "Former heat recovery systems were". This month we would have incurred a much bigger bill since a/c's didn't run. What a waste!
The A/C's were off for 10 of the 30 days in November.
One Solar Attic Fan in place with 40 watts feeding it.
The second fan will be installed next week.
We turned on the a/c heaters last night due to night time temperatures dropping to 38 degrees, poor farmers are taking a beating this week.
Conservation is very good.
Did you get the foam and fiberglass done? -
No
CC Bayseal Foam is scheduled for 12/14 -
Don't forget the R40 blown in ... made a huge difference in my home -
Sure Temp Manufacturing called me again today. This time it was the finance manager wondering if I was going to sign the lease. Poor fellow had no idea what my situation was. I asked him should I sign a lease for $260 a month when my electric was less than half of that. He said "Only a fool would do that"
Sure Temp Manufacturing is overstocked with Evergreen Panels, I wonder why? -
Re: Leasing PV System in South Florida, need advice please!Solar Guppy wrote: »Don't forget the R40 blown in ... made a huge difference in my home
I won't forget, hoping I can afford it after the CCF & Xmas. -
What kind did you use? I am entertaining bids for fiberglass & cellulose.
Your thoughts please -
Fiberglass, the stuff they blown in and looks like snow. a blow-over should be in the 900-1600 price range based on all the homes I seen done around here ( based on my suggestion for efficiency improvements ), but you home is larger SF
I am not a fan of cellulose, it compacts faster than fiberglass and regardless of the sales literature, I don't like the idea of more paper products in the attic for insect and fire reasons
How did the foam work out? pictures? -
I actually agree with SG about cellulose. That said, cellulose has more R-value per inch if my feeble memory serves. One thing to remember with all blow in insulation is that it will settle in time. I was in the attic of a house the other day that had R-40 blow in when I built it ~ 15 years ago. The white fiberglass had settled to about 1/2 as much loft as it had when new. Blow in is pretty cheap, so blowing in a new layer now and again is not a bad idea. Two other issues with blow in is making sure that the insulation doesn't block intake soffit vents, so proper baffling is essential and the other is to make sure that it is reasonably even throughout the attic. Blow crews are not known to make sure it is done evenly (or even completely) so it pays to check to see that you get what you pay for.
Tony -
Thanks for the advice, I am waiting on 2 other bids for blown fiberglass.
Foam looks good, pretty even at 1" throughout, smells odd. -
Insulating values of various materials
type R value per inch
vac ins panel 54
fiberglass 3,1 batts
fiberglass 3,6 high density batts
fiberglass 2,5 loose fill
straw bales 1,45
still air 5
still air with 1 convective currents
wood chips 1
vermiculite 2,13 loose fill
perlite 2,7 loose fill
fiberglass 2,7 loose fill
rock & slag wool 2,5 loose fill
rock & slag wool 3 batts
cementious foam 3
cellulose 3 loose fill
cellulose 3 wet spray
cotton batts 3,7
icynene spray 3,6
urea-formaldehyde 4 foam
urea-formaldehyde 4 panels
phenolic spray 4,8 foam
phenolic 4 rigid panel
polystyrene 3,7 EPS - molded expanded low density
polystyrene 4 EPS - molded expanded high density
polystyrene 3,6 XPS low density
polystyrene 4 XPS high density
polyurethane 3,6 open cell spray foam
polyurethane 5,5 closed cell spray foam
polyurethane 6,8 rigid panel pentane expanded initial
polyurethane 5,5 rigid panel pentane expanded after 10 years
polyurethane 7 rigid paneş CFC/HCFC expanded initial
polyurethane 6,25 rigid paneş CFC/HCFC expanded after 10 years
polyisocyanurate 6,8 rigid panel pentane expanded initial
polyisocyanurate 5,5 rigid panel pentane expanded after 10 years
silica aerogel 10
vac ins panel 30
cardboard 3
thinsulate clothing ins 5,75
Russ -
After investigating the costs of blown fiberglass and viewing some completed homes we went a different route. Installed Radiant Barrier on January 18th, directly to the top of current fiberglass batt insulation.
February usage bill arrived today $100.65 33 kw/day 28 days 929 kw's
I could not ask for more. The uninsulated garage is the biggest surprise, it's just cool. 8)
Next step for me is pv. I am looking into ground mounts for my backyard, any suggestions? -
Well, that will be almost nothing ...
You need insulation, a piece of tinfoil doesn't have any R value
Radiant barrier is for keeping the IR from the shingles from heating the air below, since the air will still get heated, no improvement
This time of year we all have low bills -
Re: Leasing PV System in South Florida, need advice please!Solar Guppy wrote: »Well, that will be almost nothing ...
Thank You very much
Thought I would share this thread for those who feel attic insulation and its unique ability to absorb & retain heat are important in South Florida.
I know how Sikorsky felt.
http://forum.solar-electric.com/showpost.php?p=78673&postcount=35
