Monitoring
Hi,
I've just had a new 5KW system installed, using the 5300 SOLECTRIA inverter.
It has a RS232 and RS435 port for monitoring, has anybody had any experience with it?
Thanks,
Henry.
Thanks,
Henry.
Re: Monitoring
Yes, I know this web site but they don't say you need a gateway to hook it up, I need to know about the RS232 interface, like baud rate, is it straight thru cable or null modem adapter, what format to expect, etc. -
Re: Monitoring
check out greenpowertalk.org and search for solectria -
Re: Monitoring
Thanks, that was very helpful. I got the application "PVDataManager" and it works great.
