Battery box venting - passive
bbbuddy
Solar Expert Posts: 135 ✭✭✭
http://www.bdbatteries.com/hydrogenventing.php
I searched the forums, didn't see this info anywhere.
Seems to be a "failure proof" passive venting method recommended by this battery dealer.
Has anyone done this?
We are making a small outdoor powerhouse for the new battery bank, inverter, and charge controller, so now is the time to decide on venting. We already have some 1 inch copper pipe, may have to buy a piece of 1/2 inch if I can't find any laying around. the only thing I "worry" about is, we have a couple of months of VERY windy weather, I would not want the wind to interfere with this.
Comments?
Comments?
Magnum4024PAE, 2 Midnite Classic 150s, 3100watts solar, 432ah lifepo4 battery. Off grid since 2004.
Re: Battery box venting - passive
All the wind will do (usually) is to help keep the air mixed and that is what you need to dispel any fumes from the batteries.
I think this coaxial idea is a bit of overkill but it is still attractive, anyway. I thought of doing something similar but adding an exhaust fan that would run when charging.
I haven't done the analysis but I really don't think the temperature differentials are sufficient for the rationale given for this coaxial venting system.
Another factor is the 1" pipe. I'd think that suitable only for a small, one or two battery bank.
- 224 Forum & Website
- 617 Discussion Forums/Café
