How to wire an ac/dc pressure switch to dc pump.
In an effort to conquer my Edison bill, I installed solar heat panels for our jacuzzi and dropped a Grundfos 11-sqf-2 pump in one of our 3 wells. No pressure tank, just a 3000 gal. and 2700 gal. storage tanks. The pump pumps into the 3000 gal. tank, overflows into the 2700 gal tank we use out of and from there overflows again onto a row of citrus and avocados. The system works brilliantly, so now my husband has gotten enthused and that's the problem. I have bought another ll-sqf-2 pump to drop into a second well and my husband wants it hooked up to a pressure tank. O.K., that should work just like a pressure float, no problem, right? The problem is that he has a 5 wire ac/dc pressure switch he wants to use. From what I've read, dc pressure switches are 3 wire. My idea of wiring the system is solar power to cu-200 controller then from the controller, 3 wires to the pump and 3 wires (but which 3 wires?) to the pressure switch with the controller turning the pump on and off. He wants to run solar to cu-200, 3 wires to the pump, 3 wires to the pressure switch, and 2 wires from the pressure switch to the pump, assuming the pressure switch will control the pump. I'm no electrician, but I can't see how that would work. It's not for nothing Grundfos pumps are great, and I can't afford to let him burn up either the pump or the control box. He won't listen to me, but he might listen to you. Can anyone out there advise me about wiring a 5 wire ac/dc pressure switch up to a dc pump? Maybe I should bite the bullet and buy one of those way-too-expensive Grundfos pressure switches? My electric bill, by the way, has dropped from hovering around $300. a month to running between $35. to $40.00.
Re: How to wire an ac/dc pressure switch to dc pump.
Without knowing the actual switch in question, it's difficult to say.
Pressure switches in general have four connections: two for power in, two for power out. It is possible the fifth wire is merely a safety ground (which they also have).
Considering how expensive the pump is, I'd say don't muck about; get the recommended unit and wire it in the recommended way. I strongly suspect the Grundfus controller needs the right switch in order to function properly, as it isn't just a matter of "fixed power source; turn pump on when pressure is low, off when it is high." -
Post a pic or the specs for this switch. We than can give you/your husband better answers. Till then, DO NOT wire anything up !!!!!!!!!! -
Thanks so much for your responses guys. After reading them, my husband has come to the conclusion that we need a Grundfos pressure switch, which I have ordered. We're dropping the pump down the well now, and soon my water runneth over. Amazing critters those Grundfos pumps!
