Solar panels - 260 watt 12vdc system
easytim
Solar Expert Posts: 57 ✭✭✭✭
I put together a web site of my solar project http://solar.led-guy.com/
Please feel free to comment good or bad, its a learning project, I'm sure I can improve. Its just a simple project no biggy
Re: Solar panels - 260 watt 12vdc system
you bought all this stuffi want to build my panels
My first quick look reveals a BZ controller, which is know on these forums a a real POS! I have found from personal experience, that the power output through a BZ controller is often less than if you used no controller at all. Please do a search on these boards of some more info on these controllers.
Other than that, it looks like a nice clean system,
PS. Welcome to the forum. There are some very smart folks here who have forgotten more about RE than most of us will know. -
I noticed you bolted your L feet dirrectly to the roof! I see no sealant or did you use any? Any leaks? I've been thinking of doing this or biting the bullet and using FastJacks. -
Re: Solar panels - 260 watt 12vdc systemI noticed you bolted your L feet dirrectly to the roof! I see no sealant or did you use any? Any leaks? I've been thinking of doing this or biting the bullet and using FastJacks.
I sealed the bolt, no leaks -
Cool, I had asked before if anyone had done this.
You just squirt 3M 5200 into the hole then tighten the bolt right?
Or did you use some other sealant?
- 231 Forum & Website
