sw4024
Does anyone have used parts ?
I brought my inverter to a service teck in Tuson because it seemed to have a bad relay.
When he powered it up it caught fire. Now I need several parts.
I am waitting for the part numbers from him.
I think he wired it wrong because I disconected it and reconected it several times with no problems (other then the relay that turned on and off and on again).
Re: sw4024
Time for a new inverter.
As venerable as the SW is, you'll find a lot of posts on this forum about them failing after years of faithful service - and how difficult it has become to get parts and service.
Nothing lasts forever. Someday even I will be gone.
You can all stop cheering now!
Re: sw4024Cariboocoot wrote: »Time for a new inverter.
A new inverter for $4000 is out of the question. Thanks -
Re: sw4024A new inverter for $4000 is out of the question. Thanks
You don't necessarily have to buy the $3,000 XW replacement:
http://store.solar-electric.com/maenms4040wa.html
Otherwise you're stuck trolling for used SW's.
Maybe someone else around here has a better solution.
- 230 Forum & Website
