Solar Afloat #6 Panel Power
Highland_Fling
Solar Expert Posts: 37 ✭
Rather unsurprisingly the bigger output panels are LARGER
:grr..............is the greater output a function of more individual cells in the panels or bigger area cells or a combination of both or what?
Re: Solar Afloat #6 Panel Power
"Full noon time sun" is around 1,000 Watts per Sq.Meter...
So, the amount of power a panel generates is some fraction of what falls on the panel... Thin film panels tend to be in the 8% efficiency range and crystalline panels are in the 13%+ range.
The number of cells and how they are arranged (series/parallel) does not really affect the panel's output in watts... The the Voltage and Current:- Power = Voltage * Current
However, the thin film/less efficient panel will be larger (more square foot/meter) than the more efficient crystalline solar panel.
But, both types of panels (thin film or crystalline panels) will output roughly the same amount of power if they have the same rating i.e, 205 watts, etc....
Rethinking you answer it did not answer my question really - assuming panels from the same manufacturer a KD-135 and a KD-185 - is it just more area and bigger cells that makes the KD-185 more powerful or is it more cells or what?
However if i have two 185W panels and a 15W controller at max sun the controller will be only able to handle/output 15W but up until then when the controller maxes out - in marginal conditions will two KD-185W panels outperform two KD-135W panels
i.e. over the whole day will the two bigger more expensive panels outperform two smaller cheaper panels in A/H 's assuming that both can deliver 15W or more in max sun conditions -
Re: Solar Afloat #6 Panel PowerHighland_Fling wrote: »OK thanks so if i have two 185W panels and a 15W controller at max sub the controller will be only able to handle/output 15W but up until then will two 185W panels outperform two 135W panels
I am confused... Are you asking about the MorningStar 15 amp MPPT type charge controller running on a 12 volt battery bank? (instead of a 15W controller?)
If so--then yes, a pair of 185 watt panels will produce more power in "low light" conditions than a pair of 135 watt panels in the same conditions. Once there is sufficient light on the 185 watt panels to for the controller to hit its 15 amp limit (at ~14.5 volts)--then any more sunlight will not result in any more power as the controller is already at its physical limit... For example, the 2x185 watt panels may hit the limit between 10-2pm. Where as the pair of 135 watt panels may hit the limit only a few times a year for an hour or less at a time...
If you had a 30 amp MPPT controller instead, then the 2x185 watt panels would supply enough energy for the 30 amp controller to output more than 15 amps during the (for an example) 10am-2pm period--and you would have more power collected in the day (and that is assuming your batteries are not fully charged by 10am and "tossing away" energy the rest of the day anyway.
Battery Capacity, amount of power used during day/night, size of panels, size of controller, etc. all play together as too how much useful power you can collect from your solar panels on any arbitrary day.
For an off-grid system--You really never plan on using every watt generated by the solar panel every day (100% usage). There are some days where you will use more power than generated (battery bank does not fully recharge) and there are other days when you will use less (bank comes back to 90-100% State of Charge).
Well... Yes... Just like if I hooked up my 3.5kW grid to a MS 15 amp MPPT controller--The controller would be capable of outputting 15 amps from about 7:30amp to 6:30pm on a typical July day... However--If I had a larger controller and battery bank, I could instead of harvesting ~217 watts limit during the day time, a larger controller would be able to harvest 2-2.5 kW during the 10am-2pm time frame...i.e. over the whole day will the two bigger more expensive panels outperform two smaller cheaper panels assuming that both can deliver 15W
So, there is a place for larger controllers too. For optimum sizing--I use the 0.77 typical derating for solar panels and controller losses so that a "nicely sized" array for a 15 amp MPPT controller running on a 12 volt battery bank would be:- 15 amps * 14.5 volts * 1/0.77 derating = 282 watts...
We can see that on an average summer day (20 year average/typical day), that the output of a 370 watt array with typical derating of 0.77 fixed mount array tilted at latitude would average 268 watts between noon and 1 pm.1970, 7, 25, 07:00, 6.5
1970, 7, 25, 08:00, 62.0
1970, 7, 25, 09:00, 135.0
1970, 7, 25, 10:00, 203.9
1970, 7, 25, 11:00, 241.4
1970, 7, 25, 12:00, 262.9
1970, 7, 25, 13:00, 268.3
1970, 7, 25, 14:00, 258.6
1970, 7, 25, 15:00, 230.8
1970, 7, 25, 16:00, 182.4
1970, 7, 25, 17:00, 112.4
1970, 7, 25, 18:00, 38.0
1970, 7, 25, 19:00, 0.1
However, the maximum output of the 15 amp controller is ~217 watts--So, during that 1 hour period, such a setup would "lose":- 268 WH - 217 WH = 58 WH
Something like a 10% loss over the whole day with "over-sized" panels on an undersized controller for this one day.
I guess it is your choice as too how much power loss in a day/year vs a cost of a larger power supply is to you...
Is what I wrote above clear?
Having gone for a walk i edited and rephrased my question sadly my edit and your reply crossed.
Thanks for that added input and yes the controller i have and talk about is the Morningstar MPPT 15L OOOPS YES 15A not 15W
And the two controllers i am interested in as an upgrade IF i dont go down a two systems two MS MPPT 15L controller route is the MS 45 and 60 AMP models.
I need to read your big reply more slowly and carefully and think - have you answered my question as to which panels will produce more A/H's a day.
Yes i am charging batteries and running a number of 12V appliances two 12V Fridge and Freezer compressors lights all LED now :-) a 12V Mini ITX computer system with flat screen and two laptops as well as an Inverter. When sailing the load goes up significantly BIG Autopilot Radar and a number of instruments including a large MFD - Chart Plotter/Radar display and no i have not sat down with Excel and worked out my A/H usage When on the move we run the engine say two hours a day one hour as we leave and an hour when we arrive The engine has 90 A alternator. I AM a Sailor and would sail the anchor out and in BUT the anchor windlass wont work without the engine running and the Cold Plate in the fridge has an engine driven compressor that takes 45 mins to get that cold plate frozen. At anchor we 'tend' to get great sunlight generally up the stern and the panels are angled to pick that up Sailing things are obviously not as simply but we do have lots of sunlight in general We use factor 50 sun block though that is because we get reflected sunlight the solar panels will only get direct sunlight and for around at least 11 hours a day.
Where we sail in the Caribbean the Virgin Island i just grabbed this info off Wunderground.com
July 25, 2010 Rise: Set:
Actual Time 5:55 AM AST 6:57 PM AST
Civil Twilight 5:31 AM AST 7:20 PM AST
Nautical Twilight 5:04 AM AST 7:48 PM AST
Astronomical Twilight 4:35 AM AST 8:16 PM AST
Moon 6:44 PM AST 5:26 AM AST
Length Of Visible Light: 13h 48m
Length of Day 13h 01m Tomorrow will be 0m 40s shorter.
Assuming my MS MPPT 15L is maxed out then surely i dont need to de-rate by your .77??? that will be a true 15A into my batteries assuming they are needing charged?
YES quite clear - so really three 100W panels - the nice and cheap Sunwize ones http://www.solarblvd.com/Solar-Panels-&-Systems-Individual-Solar-Panels-100---170-Watt-%2812%29/c1_25_42/p854/Sunwize-SW100C-100W-12V-Solar-Module/product_info.html should be an ideal match for my MS MPPT 15L being just a tad over your 282 watt figure? AND they have junction boxes not silly proprietary solar panel connectors.
thanks again
kindest regards
David
P.S. where is the thank you button on this forum!!!! - 15 amps * 14.5 volts * 1/0.77 derating = 282 watts...
- 234 Forum & Website
