California State Power Operator adds Wind-Power to daily reports
BB.
Super Moderators, Administrators Posts: 33,714 admin
For anyone that is interested--Cal ISO (Independent System Operator) which brokers the majority of electrical power inside California between generators and utilities (which are now, more or less, power distribution companies) has added Current Wind Production to their real-time graphs (and details on renewable energy as a whole too).
www.caiso.com/outlook/SystemStatus.html
Re: California State Power Operator adds Wind-Power to daily reports
This is great! I like this stuff. Does Texas have something similar? -
Cool!
They also have a PDF with renewable data from the previous day including solar, but there's no way the solar data includes any significant number of PV installs (and certainly no residential installs), otherwise the shape would be much more parabolic. -
Re: California State Power Operator adds Wind-Power to daily reports...but there's no way the solar data includes any significant number of PV installs (and certainly no residential installs), otherwise the shape would be much more parabolic.
Yea, I wondered why solar curve looks so flat. Probably because the source is concentrated solar thermal power. The reduced demand effect from distributed PV installs should leave it's mark on system-wide power demand graph. Maybe when smart meters that can send data to utility in real-time are rolled out, we will see distributed PV contribution included.
Does anyone notice that there is about 250 MW of wind power just suddenly drops offline at 5am? That does not look normal.
I like how nicely solar complements wind power - wind dies down around noon when sun is strongest. -
Good point - should be possible to visualize by looking at historical data...Yea, I wondered why solar curve looks so flat. Probably because the source is concentrated solar thermal power. The reduced demand effect from distributed PV installs should leave it's mark on system-wide power demand graph.
Would need 2 smart meters - one to read load from the house, one to read PV generation.Maybe when smart meters that can send data to utility in real-time are rolled out, we will see distributed PV contribution included.
They probably took some wind offline for maintenance. 45min later it jumped back up.Does anyone notice that there is about 250 MW of wind power just suddenly drops offline at 5am? That does not look normal.
Peak loads seem to be late afternoon early evening (4-5pm). Unfortunately, PV output is usually down 30-40% off peak output by that time of day. Would have to start aiming panels west if the goal was to reduce peak loads.I like how nicely solar complements wind power - wind dies down around noon when sun is strongest. -
What's that second small peak on the Load Graph at around 8pm? I am guessing water heaters as people take showers. On other thought, could be water pumps. -
I believe it's from people turning on their computers and getting on the internet...What's that second small peak on the Load Graph at around 8pm? I am guessing water heaters as people take showers. On other thought, could be water pumps. -
From what I can tell there is about 1GW of solar power installed in California with about 1/3rd of it being concentrating solar - that definitely explains the Solar data we're seeing (and not seeing).
There is about 300MW of PV that is currently in the process of being installed through the CSI rebate program: http://www.californiasolarstatistics.ca.gov/
There were a lot of large commercial projects requested in the past couple months that make up the vast majority of that 300MW that is pending - 40MW in March/May, 120MW in April.
BTW - that 300MW is in CEC-AC, not STC watts so it should be reflective of actual peak power output.
The goal is to get 1.75 GW of PV installed by 2016 and 3GW of PV installed total.
Wow, that CSI rebate site I listed above has a search utility that lets you search by manufacturer and/or specific model including inverters and panels.
- 232 Forum & Website
