Xantrex SW 2000 inverter aMPS?
Nomore
Registered Users Posts: 18 ✭✭
My uncle is looking for an inverter, I have read extensively here and I am considering the sw2000. He will only use it occasionally when there is a power outage and wants to be able to power his refrigerator. He keeps asking me how many amps this inverter is able to handle and I cannot find that info anywhere. If someone know would you mind sharing with me.
Re: Xantrex SW 2000 inverter aMPS?
now that is math as the continuous power is 2000w and the lowest voltage is 10.5v so 2000/10.5=190a. however, they recommend a 150a fuse so it will be that fuse as the limiting factor.
http://www.xantrex.com/web/id/297/p/2733/pt/5/product.asp -
Re: Xantrex SW 2000 inverter aMPS?He keeps asking me how many amps this inverter is able to handle
If it is AC load he is asking about 2000 watts is 16 amps at 120 VAC. -
Re: Xantrex SW 2000 inverter aMPS?If it is AC load he is asking about 2000 watts is 16 amps at 120 VAC.
Thanks for the info, that is what I wanted to know.
