Best way to equalize batteries off-grid - Cheap Generator?
cdre
Solar Expert Posts: 78 ✭✭
In the past, I've used a 2 stroke 1000w generator run for 12 hours or so to equalize my 12v RV sytem with 4 12v batteries.
Shifting over to a 48v system and trying to ensure I take care of my batteries, I'm wondering what the most cost effective way to equalize is... I wonder if I can get away with the same small generator idea...
How are you guys doing it?
Re: Best way to equalize batteries off-grid - Cheap Generator?
What is the AH rating and voltage of your battery bank?
A good quality power factor corrected AC battery charge mated to a good quality genset of appropriate size is still not a bad way to go for charging/backup power.
Ideally, for most generator you want to run them at a minimum of 50% load for good fuel efficiency. The Honda eu2000i can run down to 400 watts / 25% load at good fuel efficiency because of the inverter/generator (allows engine to throttle back to a lower speed when power requirements are low).
But, this all has to match your battery bank + battery charger for optimum cost and fuel usage.
I'm looking at a Northstar Trifuel 6.6kw generator for typical use (surge loads and bulk charging), but thinking a smaller gen would be better for long equalization (float) runs... Battery bank likely to be 16 T-105s in two 48v strings with an Outback FX3048T.
I always keep a smaller generator handy as a backup anyway, but wondering if I can get away with the 1000w disposable chinese generator for a monthly battery burn. I'm not sure if it would have enough power to supply that equalizing charge. -
Your choice on the small generator... How many hours do you expect on the 1,000 watt guy vs the 3,000 hours +/- that you could get on the much more expensive (and quiet) Honda eu2000i (1,600 watt rated).
I've actually had 2 of those units, and I can't complain too bad... The biggest problems I've had is carbon buildup at the exhaust (too much 2 stroke oil) and pull cord failures. Carbon bulidup occured after about 6 months of 2 hours or so daily (before I went solar). If I'm running the generator very infrequently I won't be pulling on the cord all the time (less starting wear and tear).
While the metallurgy on those little engines isn't comparable to a honda engine, as long as you buy them knowing they are disposable, they are very handy.
