Aerosharp inverters
phred01
Solar Expert Posts: 35 ✭
Hi all
I have one these inverters from a new batch. The problem is a window based s/w pvmonitor 2008 no longer works with the current model. Has anyone a data logging windows program that's available?
Re: Aerosharp inverters
For those who have an Aero_Sharp inverter here is a home grown Windows
Display monitor This program works with latest units as well as the
older ones
Conditions of use
1 Must be a registered member of wind & sun
2 For personal use only (educational purposes)
3 No commercial licence on use is implied I reserve all rights
4 s/w was developed and compiled with Labview evaluation package
5 Respect National Instruments licencing use see their site
Now register with NI (Free)
DNL labview 9 runtime engine
http://joule.ni.com/nidu/cds/view/p/id/1383/lang/en
Install
Dnl the following
http://www.megaupload.com/?d=GBSCHZC1
You will need to make a RS485 connection to the inverter
You may void your warranty by doing this
Use the linux guide found here http://www.ozzicomp.com/aerosharp/ or
Start reading from here
/forum-replies.cfm?t=1465841&p=4
http://i34.tinypic.com/2h3bktk.jpg
http://i55.tinypic.com/15gqf41.jpg
Plug to the inverter can be bought here thanks to bits&pieces
Bits&pieces writes...
grab one of these CTB92HE/2 a Melbourne store Semtronics
To date unit does not store any data to disc just the displays
If comms port needs to be changed press stop wait until run (white)
appears on toolbar select comms port then press white arrow. The s/w ready to run. Press the green run button
Many Thanks to Bits&Pieces for help and beta testing
Enjoy
