Inverter Ground Wire Size??
joeedens
Solar Expert Posts: 28 ✭
What size wire should be used for the DC chassis ground on the VFX 3648 Inverter? The DC cables are 2/0 AWG. Thanks for any help.
Re: Inverter Ground Wire Size??
If you mean the DC chassis grounding lug, I believe it will hold 6 AWG.
