Solaron Transformerless Inverters .
Batikikik
Solar Expert Posts: 141 ✭✭✭✭✭
I can see most of the installers use Solaron 500KW and 333KW transformerless inverters. I have never worked with whatolaron befor but I have very good impression. First size are very small and compact, AC wiring side is simple and efficiency and monitoring is the same as Solectria, Pvpowered etc.
But what is the biggest advantage of transformerless Solaron inverter ?
Thank you
Thank you
Re: Solaron Transformerless Inverters .
there was a discussion long ago on transformer vs transformerless and from what i recall of it it was getting more efficiency with raising the safety risk some in the event of parts failure for going transformerless.
