Wiring a second string to A/C cutoff sw?
st2288
Registered Users Posts: 9 ✭
Currently I have a string of 12 sharp 235w into a Sunnyboy 4000w inverter (2800w max). I want to add 3-200w (600w) canadian solar using enphase inverter.
My question is can I wire the output of the enphase inverter (240v) into the sunnyboy A/C cutoff switch (on the same side) ? The other side of the cutover switch feed back to a 30 amp breaker in the panel.
Re: Wiring a second string to A/C cutoff sw?
I wire the output of the enphase inverter (240v) to a ac cutoff. I tied the Sunnyboy ac output to the output of cutoff switch. I can't wire directly into the outdoor switch because the utility company place a tag on it.
enphase ----> cutoff ---->
> Outdoor AC cutoff.
Sunnyboy (AC output) ---|
Dont know if that make sense -
Not quite clear what you've done, but if you want to only use one AC disconnect, you need to combine both the PV circuits into a single panel using a sub-panel.
Your sub panel will probably have a 20A breaker for the SunnyBoy 4000 and a 15A breaker for your Enphase circuit.
