8 L-16's @ 48v what should be the max amp charge
WD-40
Registered Users Posts: 15 ✭
I have 8 L-16 batteries on a 48 volt setup.
Xantrex 5500 inverter, what should i set my max amp charge to?
What should i set my bulk voltage to?
What should i set my float voltage to?
What should i set my float amp cut in to or at what amp should it switch to float.
I use a 10kw diesel gen
Thanks!!!!
Thanks!!!!
Re: 8 L-16's @ 48v what should be the max amp charge
Trojan has their charging voltages here:
http://www.trojanbattery.com/BatteryMaintenance/Charging.aspx
Rolls here:
http://www.rollsbattery.com/content/marine-battery-technical-bulletins?q=node/47&phpMyAdmin=0610e516bf803196b5feee0b1ad65c08&phpMyAdmin=3jSJ-jdC5E7b53DHgV8TGvpSCF6
According to our host's battery FAQ:
"Most flooded batteries should be charged at no more than the "C/8" rate for any sustained period. "C/8" is the battery capacity at the 20-hour rate divided by 8."
http://www.windsun.com/Batteries/Battery_FAQ.htm
Not knowing the exact rating of your particular batteries, let's assume a 320ah capacity at the 20hr rate.
320 / 8 = 40
Since your batteries are probably 6v x 8 wired in series to give 48v, then the amp hour capacity of the entire bank would be 320 - so the charging amperage should be 40a or less.
