solar furnace
AmDD
Registered Users Posts: 5 ✭
Hello all, I have been researching solar hot water heaters and came across some videos on youtube about a solar furnace made of soda cans. Its a neat idea and seems to work. I would like to find more info on this, specifically a write up on it rather than a video and more info on the electrical side (fan, battery if needed, charging system, inverter, thermostat, etc). I tried searching but im not sure of the actual terms to search for. Any one have experience with this or know what I should search for to get some answers?
thanks!
thanks!
Re: solar furnace
Check out Build It Solar http://www.builditsolar.com/ for lots of ideas about passive solar!
It's one of my favourite "ideas" sites.
Re: solar furnace
cool, thanks for the link! "passive solar" is that what this is actually called? -
Re: solar furnacecool, thanks for the link! "passive solar" is that what this is actually called?
Yup. "Passive solar" is any type of solar that doesn't introduce an external power source (such as a pump or fan).
This excludes solar electric because you either have a grid tied in or batteries to recharge.
Although I'd be hard-pressed to say about direct-from-PV pump set-ups.
