D/C Amp Meter
GreenPowerManiac
GreenPowerManiac Solar Expert Posts: 453 ✭✭✭
Could anyone recommend a decent DC amp meter 0-100a for less than $50.00 ?
Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
WWW.GreenAnything.Net    Ad free website.
    Re: D/C Amp Meter
    Clamp or shunt?
    You can get a shunt and wire it into the circuit pretty cheaply.
    A decent DC Clamp meter is probably on the order of $100 starting price (and UP)...
  • GreenPowerManiac
    Re: D/C Amp Meter
    Point us the way to the good one.....
    Please describe either DC meter option:
    Re: D/C Amp Meter
    Well, in no particular order... (OK, I lied, starting from cheapest ;))
    • Shunts: Basically a calibrated power resistor with a pair of heavy connections for the power, and a pair of small connections to connect a milli-volt meter (I=V/R)
    wind-sun_2106_20552094Deltec 100 amp, 100 millivolt current shunt
    AC or DC - common item for use with many battery monitors and amp meters
    • Next, I really like meters that can measure Amp*Hours and Watt*Hours... To that end, the Watt's UP and Doc Wattson seem to be a good deal. Read the support manuals--they have suggestions on how you can measure current in excess of 60 amps.
    For inexpensive clamp on DC Amp Meters, the Extech meters seem to look OK. The MA220 looks interesting at $100 (Jameco Electronics is a couple miles from my home and I have purchased some inexpensive equipment from them over the past decade).
    Then there are Battery Monitors (external shunts and multi-function meter heads). The higher end units can have Peukert Factor correction in them too (the higher the current, the lower the apparent battery capacity):
    NAWS
    Victron
    Above that, I have used current probes from Techtronics (decades ago)--great for connection to a oscilloscope to measure exact current wave forms. I have also used a Fluke Meter Current Clamp...
    All have their limitations--And I have found (at least for me), the less expensive current probes I have used tend to wonder around zero current pretty significantly.
    If I needed to measure accurate/low amp currents (less than a few amps on either side of zero) and log those over time--I would tend towards using a current shunt for its long term accuracy. Also, with a shunt, you can connect various multi-function meters (amp*hour, watt*hour, battery monitors) and get more information about my battery bank's condition over time.
    If I needed to just check the current flow through various DC circuits for diagnosis and the occasional checkup--I would go with the DC current clamp (zero, then clamp, zero then clamp, etc.).
  • GreenPowerManiac
    Re: D/C Amp Meter
    I chose the MA220 Extech Clamp type. Actually found one on the Bay for $40.00.
    I'm a "Tools" collector anyhow and I don't have one of those...yet. Thanks for the tips.....
    Re: D/C Amp Meter
    GPM,
    Lets us know how it works for you--I have been wanting a DC clamp meter for personal use for years... Just too cheap to buy one. :roll:
  • Dave Angelini
    Dave Angelini Solar Expert Posts: 7,123 ✭✭✭✭✭✭
    Re: D/C Amp Meter
    Bill,
    I also have the model that GPM has. It works very well. I have found a few bad stranded wire connections that needed torqueing on array strings. My old Fluke got run over by my brother-in-law...Give it a 9 on a one to ten. As you suspect, it is not perfect!
    E-mail offgridsolar@sti.net
