24 volt hookup to 12 volt
System Posts: 2,511 admin
can a 24 volt panel be used in a 12 volt system with a 12 volt charge controler
    Re: 24 volt hookup to 12 volt
    it can, but it's not advisable to do so as losses would be very high if the controller can handle the higher voltage going through it unless as bb points out after me that it is mppt.
    Yes... But:
    1. If done with a PWM charge controller (cheap ones)--you will lose about 1/2 of the panel wattage when charging the battery bank
    2. If done with a MPPT charge controller (expensive ones)--Perfectly OK and can be the ideal solution for many people/setups (but price is still an issue).
    In any case, you need to look at the input voltage/current limitations of the charge controller and make sure your panel setup does not exceed the limits.
    All About Charge Controllers
    Read this page about power tracking controllers
