What to do with a broken kyocera well pump
System Posts: 2,511 admin
are there any other options except replacement?
    Re: What to do with a broken kyocera well pump
    that might be something kyocera would probably have to answer. i would also suppose that would depend on what on the pump broke as not everything may be fixable on it or at least worth the cost of fixing it.
    Also, it would help if you posted a link to the model you have (if there is one) or gave a model number/description. Seeing what kind of pump you have would help others here give you some options on repair and/or replacement.
    Good Luck!
  • Windsun
    Windsun Solar Expert Posts: 1,164 ✭✭
    If is is the SolarJack type, see www.sunpumps.com
    They have repair parts for most (not all) of the older Kyocera pumps.
