Batteries DOD %'s?
adam1984
adam1984 Solar Expert Posts: 72 ✭✭✭✭
So here's my confusion. I thought I had understood that depth of discharge was essentially how low can the battery drain. I was under the assumption that when a battery has a 100% discharge (a 12V battery for example) would read 0 volts. I read its recommended not to go past 50%, what I thought was 6 volts. I then read that you have set points on a charge controller, and you shouldn't let it go below 11 volts??? So does that mean you should only have a dod of 8%? I dont get this. Any help is appreciated.
    Re: Batteries DOD %'s?
    0 volts is not the point or reference where a battery becomes dead. typically for a 12v battery the dead point is 10.5v unloaded also listed as 0% soc or 100% dod.
  • icarus
    That is actually a very good question!
    I suggest you look through here:
    http://www.batteryfaq.org/
    http://www.windsun.com/Batteries/Battery_FAQ.htm#Lifespan%20of%20Batteries
    Sometimes we forget that there are obvious questions that almost seem too simple on their face, but are n fact much more complicated.
    Welcome to the forum and feel free to ask away!
  • john p
    john p Solar Expert Posts: 814 ✭✭✭
    Adam1984 to give you an example you may be more familiar with. ever used a flashlight ?with say 2 D cells? when those batteries are new they have about 1.6 v in each when "dead" they have about 1.1 v in them, same goes for the "AA" or "AAA" batteries in your remotes for TV ,DVD player etc
    Batteries are voltage sources and (ideally) the chemical processes in them hold the voltage stable until the chemical reactants are depleted--then the voltage will collapse.
    However, batteries are not ideal and show some voltage vs state of charge characteristics.
    Something like a capacitor will have a direct relationship between voltage and state of charge:
    Notice that the stored energy goes up with the square of the voltage...
