set equalize time
How can you set the length of time you want to equalize your batterys on a xantrax hibrid 4024 inverter.
Re: set equalize time
On my SW4024SC,
it is done in the Battery Charging Menu (10).
It's the 4th and 5th setting down.
I use the default settings on my L16's
in a 24vdc system
(28.8 vdc)
(02.00 hr) -
To my knowledge the XW 4024 equalization is an auto 30 minutes.
If you wish to EQ longer you will have to enable EQ again.
I think the reasoning is to be able to take SOC readings without damaging your battery bank. -
Re: set equalize timeComputerGrampa wrote: »On my SW4024SC,
in a 24vdc system
(28.8 vdc)
(02.00 hr)
What brand of batteries are your L-16's? Is that what the manufacturer recommends?
28.8v seems to quite low for a 24v system equalize setting.
Usually it would be between 30 - 31v
28.8 is more like the typical absorb setting.
I'm just curious. -
Whoa!
Do not automatically equalize batteries, okay?
Check the Specific Gravity about once a month and only equalize if you find readings are different by more than 0.010.
You should EQ manually, for one hour, then re-check. If there's still a difference, do it again. If there's no further improvement, stop. "Over equalizing" is a sure-fire way to kill batteries. The extra Voltage creates heat which can damage the plates.
And of course the Battery FAQ link: http://www.windsun.com/Batteries/Battery_FAQ.htm -
Marc/Cariboocoot noticed that this was in the wrong forum... Moved to Off-Grid Forum (was in FAQ's).
Thank you Marc!
Unfortunately, one thing I can't do with my Morningstar Prostar is change the auto equalize function. It is set to equalize every 25 days which in my opinion is way to often.
