Pumping from spring
Hello all
We have a spring on our property that tested perfect for us to use & produces about 7 gpm. Our usage will never go beyond 300 gpd . I have a 2500 gallon storage tank placed apprx. 40 feet above the house so we do not need to use pressure & we are intending to let the tank flow any extra water to a pond below the house.
Problems that I have are as follows.
220' of lift to tank
need only 1gpm more is ok
700' from spring to tank
Any thoughts
Mike
Any thoughts
Mike
Re: Pumping from spring
Mike,
The application guide at the following link may help you design a solution: http://www.solar-electric.com/PDF_files/Solar_Pump_Guide.pdf
My (gu)estimate is that you'll be facing a total dynamic head of >100 psi. A pump like this one might work for you: http://www.shurflo.com/pages/new_industrial/Industrial/gen_industrial/genind_doc_sum/8035-963-239.html
Good luck!
Jim / crewzer -
crewzer
Thanks for the link.
Mike
