water wheel electrical generation
Robert Lake
Registered Users Posts: 9 ✭
I have an 8' water wheel half built and ready for bucket installation. Has anyone built one or had any experience with one? My water flow will be low so I am looking for a small alternator or PM motor that won't overload the capability of the wheel.
Re: water wheel electrical generation
The Micro-hydro issue!
I suggested it as a potential topic, but there's not many into it around here.
http://forum.solar-electric.com/showthread.php?t=5455
Someone sent me a very nice link to a more suitable site for this, but it's on the wrong computer and I don't have access right now.
I'm sure it'll come up again; lots of nice, helpful people here. -
This is the other link I was sent by RalphDay:
http://www.greenpowertalk.org/ -
It takes a LOT of water to get much shaft horsepower out of a traditional overshot type water wheel.
200 gallons/minute on a 12' wheel will only give you about 1/2 horsepower according to this site:
http://www.waterwheelfactory.com/HP%20Table.htm
Hard to believe......friend of mine down the road built a decorative wheel....about 8' diameter, about 8" wide and runs it with a stream of water out of a 1" pipe....nothing hooked to it, it just turns. I tried to stop the wheel with my hands as a brake, and was amazed how much torque it had, but was able to finally stop it....but I guess that doesn't translate to usable power when you try to hook up a generator to the shaft. -
The main problem trying to use a water wheel as a "motor" to drive a generator is its veeeery sloooow speed.. It would need gears between it and the generator and that most likely lose you about1/2 the power .
And as you said you could stop the wheel you tested with hands.. even if difficult.. Now if that wheel had the losses of gears and the drag of a generator even if it not suppling power to anything.. how fast you think it likely to be spinning? most likely not fast enough to get the generator up to a usable speed.:grr
- 232 Forum & Website
