panels deep in concrete roof
Good day, Im starting a solar project in a new home, slope roof, made of concrete, so I was thinking to surround the panels with red clay roof tiles, so the panels look more like a window or a dome on the roof than solar panels, Question. is it necesary to have air ventilation below the panels, can they be enclosed, any reazon why I should not think of this? Thanks
Re: panels deep in concrete roof
Partly, it depends on where the install will be...
Solar PV panel's Vmp falls with increasing temperature... And if you are using a MPPT type controller (either charge or Grid Tied inverter)--The drop in voltage will cause a drop in output power.
California, in my area, estimates a the difference between a 6" under panel air gap and flush mount resultes in ~5% loss of capacity during summer.
That is not a huge loss--but most people are trying to keep the losses low for best output per $$$.
If you are in an area where you don't want to advertise you have solar panels--the security aspect of looking like windows is probably a good idea (when panels were more expensive and during the energy crisis of last year--California had quite a few problems with people stealing panels from roofs--using security hardware may help, special tools to remove, but if they want it, they will get it).
