High Neutral Current (~185 A) on Elite 440 MFM with Only 28 kW Load – CT Wiring or Meter Configurati
VijayAnju
Registered Users, Users Awaiting Email Confirmation Posts: 1 ✭
Hi everyone,
I'm commissioning a 1 MW Hybrid Renewable Energy System (PV + BESS + DG) and have encountered a strange issue with the multifunction meters. I'd appreciate any insights from those with commissioning or protection experience.
System Configuration
400 V AC bus
PV generating approximately 62.4 kW
Battery charging through PCS
DG OFF
Grid OFF (Island mode)
400 V stepped up to 11 kV through a transformer
Two Secure Elite 440 multifunction meters:
BESS feeder MFM (PCS AC output)
Transformer feeder MFM (400 V side before the step-up transformer)
CT Details
BESS feeder CT: 1100/5 A
DG/Transformer feeder CT: 1500/5 A
Meter configured with 3 CTs only (no neutral CT)
EMS Readings
PV Power: 62.4 kW
Load: 28.1 kW
PCS Power: -27.0 kW (battery charging)
Battery:
SOC: 62.7%
Voltage: 1278.6 V
Current: -20 A
Power: -25.6 kW
DG: OFF
Grid: OFF
Wind: 0 kW
The EMS power balance looks reasonable.
Elite 440 Current Readings
BESS Feeder
L1 = 75.42 A
L2 = 102.19 A
L3 = 45.50 A
Neutral = 183.35 A
Transformer Feeder
L1 = 49.81 A
L2 = 65.62 A
L3 = 126.29 A
Neutral = 187.42 A
My Concern
Since the meters are using only 3 CTs, the neutral current is calculated from the vector sum of the phase currents.
With only about 28 kW of load, I wouldn't expect a calculated neutral current of nearly 185 A.
The EMS indicates normal operation, but both MFMs show almost identical high neutral currents.
Questions
Could this be caused by CT polarity (P1/P2 or S1/S2 reversed)?
Could a phase mismatch between voltage inputs and CTs produce this behavior?
Could an incorrect 3CT/3P4W meter configuration cause such a high calculated neutral current?
Has anyone seen Elite 440 meters display very high neutral current due to configuration or commissioning errors?
Are there any additional commissioning checks you would recommend before energizing the 11 kV feeder?
Any suggestions or similar experiences would be greatly appreciated.
Thank you!
