Pump remove little water
yobi
Registered Users, Users Awaiting Email Confirmation Posts: 1 ✭
I have 3panel 270w each a 2 wired motor with 300w,36v,9A when i connect in parallel the voltage is 29v when loaded what is the problem
What pump do you have (brand/model, both electrical and water pumping specifications)?
How deep is the well/water source?
What is the output (pumping to cistern? Pumping to pressurized plumbing?).
Have you measured the current and voltage from the solar array to the pump (DC Current Clamp Meter, voltage meter, etc.)?
That voltage sounds about normal for Those particular type of panels I presume they are 60 cell panels In parallel If you want her voltage you have to series wire them
Interesting setup. The voltage drop under load may be due to startup current demand or panel configuration mismatch. Proper MPPT sizing and wiring checks can help improve performance. Thanks for sharing this useful discussion.
