Xantrex Freedom 4000 custop Lfp battery settings?
patdufo1
Registered Users Posts: 1 ✭
# Existing user configuration for FEX_RVC_4048_120_60, s/n
# Release 10700 build 0009
# on Sun Apr 7 21:56:50 2002
CAN:
CANEnable: true
CANBitrate: 250000
CANProtocol: rvc
PartialNetworkingEnable: false
PartialNetworkingFrame: extended
PartialNetworkingDataEnable: false
PartialNetworkingSleepId: 0x01238F00
PartialNetworkingSleepMask: 0x03FFFF00
PartialNetworkingSleepData: "00 00 00 00 00 00 00 00"
PartialNetworkingSleepDataMask: "00 00 00 00 00 00 00 00"
PartialNetworkingWakeId: 0x00008FFD
PartialNetworkingWakeMask: 0x0000FFFF
PartialNetworkingWakeDataMask: "00 00 00 00 00 00 00 00"
TransmitTimers:
- [IsoAddrClaim, global, 1000]
- [PmInvLdShSts, global, 100]
- [PmDevMdSts, global, 250]
- [PmAssocSts, global, 500]
- [DiagMsg1, global, 5000]
- [ChgAcSts1, global, 5000]
- [ChgAcSts3, global, 5000]
- [ChgAcSts4, global, 5000]
- [ChgEqlzSts, global, 0]
- [ChgSts, global, 5000]
- [DCSrcSts1, global, 500]
- [DCSrcSts2, global, 500]
- [DCSrcSts4, global, 5000]
- [InvAcSts1, global, 250]
- [InvAcSts3, global, 250]
- [InvAcSts4, global, 250]
- [PmInvSts, global, 500]
- [PmAcStsRms, global, 250]
- [PmChgSts, global, 500]
- [PmAcXferSwSts, global, 500]
- [InvTempSts, global, 500]
- [InvSts, global, 500]
- [InvDcSts, global, 5000]
- [DateTimeSts, global, 1000]
- [ChgSts2, global, 500]
- [ChgSts3, global, 500]
- [InvTempSts2, global, 500]
ReceiveTimers:
- [DiagMsg1, 7000]
InvChg:
InverterEnable: true
InverterLowBatteryCutoutVoltageOther: 39.00
InverterLowBatteryCutoutVoltageUser: 37.00
InverterLowBatteryCutoutVoltageLfp: 37.00
InverterLowBatteryCutoutHysteresisVoltage: 4.00
InverterLowBatteryCutoutDelayTime: 10
InverterHighBatteryCutoutVoltageOther: 65.00
InverterHighBatteryCutoutVoltageUser: 65.00
InverterHighBatteryCutoutVoltageLfp: 59.20
InverterSearchModeEnable: false
InverterSearchThreshold: 50
InverterSearchDelayTime: 2
InverterOutputVoltageLN: 120.00
InverterIgnitionControl: off
ChargerEnable: true
ChargerMaxChargeCurrent: 80.00
ChargerAlgorithm: 3stage
ChargerBatteryRechargeVoltage: 50.00
ChargerAbsorptionTime: 30
ChargerBlockStart: 0
ChargerBlockStop: 0
EqualizationSupportEnable: false
DefaultBatteryTemperature: warm
BatteryCapacity: 1000.00
BatteryType: lfp
CustomEqualizationVoltage: 64.00
CustomBulkVoltage: 57.60
CustomBulkTermVoltage: 54.00
CustomAbsorptionVoltage: 57.60
CustomFloatVoltage: 54.00
CustomBatteryTemperatureCompensation: 108.00
LithiumBulkVoltage: 57.60
LithiumBulkMaxCurrent: 80.00
LithiumBulkTermVoltage: 54.00
LithiumAbsorptionVoltage: 57.60
LithiumAbsorptionMaxCurrent: 50.00
LithiumFloatVoltage: 52.00
LithiumFloatMaxCurrent: 80.00
LithiumBatteryMaxDischargeCurrent: 150.00
LithiumBatteryMaxDischargeCurrentTimer: 8
ACBreakerRating: 50.00
ACLowVoltageCutout: 80.00
ACHighVoltageCutout: 138.00
ACLowFreqencyCutout: 55.00
ACHighFreqencyCutout: 65.00
GeneratorSupportEnable: false
GeneratorSupportCurrent: 40.00
NodeAddr: 141
DeviceInst: 2
StackingMode: 7
ACInputAssociation: 19
ACOutputAssociation: 51
DCAssociation: 3
AuxManualAuto1: manual off
AuxActiveLevel1: active high
AuxManualAuto2: manual off
AuxActiveLevel2: active high
AuxSetTriggerSource1: 18
AuxClrTriggerSource1: 18
AuxSetTriggerSource2: 18
AuxClrTriggerSource2: 18
Trig0_LowBatteryVoltageSetLevel: 37.00
Trig0_LowBatteryVoltageSetDelay: 1
Trig1_LowBatteryVoltageClearLevel: 41.00
Trig1_LowBatteryVoltageClearDelay: 1
Trig2_HighBatteryVoltageSetLevel: 52.00
Trig2_HighBatteryVoltageSetDelay: 1
Trig3_HighBatteryVoltageClearLevel: 50.00
Trig3_HighBatteryVoltageClearDelay: 1
Trig4_LowBatteryTemperatureSetLevel: 0.00
Trig4_LowBatteryTemperatureSetDelay: 1
Trig5_LowBatteryTemperatureClearLevel: 5.00
Trig5_LowBatteryTemperatureClearDelay: 1
Trig6_HighBatteryTemperatureSetLevel: 45.00
Trig6_HighBatteryTemperatureSetDelay: 1
Trig7_HighBatteryTemperatureClearLevel: 35.00
Trig7_HighBatteryTemperatureClearDelay: 1
Trig8_ActiveFaultsSetNumber: 1
Trig8_ActiveFaultsSetDelay: 1
Trig9_ActiveFaultsClearNumber: 0
Trig9_ActiveFaultsClearDelay: 1
Trig10_AcGoodSetSignal: 522
Trig10_AcGoodSetDelay: 1
Trig11_AcGoodClearSignal: 523
Trig11_AcGoodClearDelay: 1
Trig12_BulkExitClearLevel: 2
Trig12_BulkExitClearDelay: 1
Trig13_AbsExitClearLevel: 4
Trig13_AbsExitClearDelay: 1
Trig14_InternalTemperatureSetLevel: 100.00
Trig14_InternalTemperatureSetDelay: 1
Trig15_InternalTemperatureClearLevel: 95.00
Trig15_InternalTemperatureClearDelay: 1
Trig16_TimeOfDayStartSet: 0
Trig16_TimeOfDayStartSetDelay: 0
Trig17_TimeOfDayStopClear: 0
Trig17_TimeOfDayStopClearDelay: 0
RemotePowerOff: false
NoLoadPowerSave: false
40SecondSellDelay: false
ACCoupling: true
BatteryEnergyBalancing: false
2HrPeakLoadShaveDelay: false
DCDCConverterEnable: true
OperatingMode: remote power off
RemoteAudibleAlarm: true
ok,I need settings for chevy volt (NMC) 49v max and 38 min,any help with the above settings would be great,works fine now but wont start the battery charge untill over 43v I need it to kick on at 38v,thanks
How do you get service?
If your product requires troubleshooting or warranty service, contact your merchant. If you are unable to contact
your merchant, or the merchant is unable to provide service, contact Xantrex directly at:
Phone: 1-800-670-0707 (toll free), 1-360-925-5097 (direct)
Fax: 1-360-925-5143
Email: CustomerService@xantrex.co
- 232 Forum & Website
