sizing and BMS Help
bytlan
Registered Users, Users Awaiting Email Confirmation Posts: 1 ✭
I got an RV solar setup at 600w of panels. I had a 12v golf cart battery/inverter (3000w) 110v AC set up. I am looking or thinking to change it all. Now looking to go LiFePO4. I have 4 - 300Ah 12v batteries. 1 also have a bad BMS on 1. I'm thinking I need to crack it open, the 1 battery or all 4 and fix with some other BMS set up?
Here are the specs I have on the battery:
Specifications
Battery type: LiFePO4 Battery
Delivery date: 2023
Nominal voltage: 12.8V
Nominal capacity: 300Ah
Maximum charging current: 50A
Instantaneous discharge current: 200A
Continuous discharge current: 100A
Life: ≥6000 cycles or more
Charging temperature: 0~45°C
Discharge temperature: -20~60°C
Storage temperature: -20~65 °C
Size: 310*193*172mm (+/-10mm)
Operating voltage range: 10.0 V-14.6 V
Overload protection voltage: 14.6 V 0.05 V
Protection voltage against overload: 10.0 V 0.05 V
Protect battery temperature: 60°C plusmn 5°C
Output and parameters: high current positive / negative connection column (red positive, black negative);
Package includes:
1pcs 12V/12.8V 300Ah High capacity lifepo4 Battery pack, with BMS build-in.
1pcs charger
China Made Batteries with no more support - learned the hard way. RV AC unit works on a 5000w generator. Could I have enough power to run this AC unit and how long? And any ideas as to changing to a 24v or 48v Inverter for the system change? And what is my best method for repairing or replacing the BMS for the 1 or all those batts via cutting them open? Any Help??
