MPPT60's keep going Charger Disabled overnight
ericsysmin
Registered Users Posts: 6 ✭✭
After enabling Grid Peak Load Shave on my XW Pro 6848's each morning I've had to re-enabled the MPPT60 chargers to start generating power from the panels. Any idea on what setting I should check that handles this.
Weird? So they are in stby every morning after you enabled it? You might have found a bug in new pro and very old mppt. Does it do this if you stop using load shave? Each mppt does this?
It is an old mppt, the dash 60. What is it's firmware?"we go where power lines don't" Sierra Nevada mountain area
E-mail offgridsolar@sti.net -
Each of the MPPT's are doing this and some are brand new (less than 2 years old).
Here's a screenshot of my XW Pro and MPPT configuration. I have two XW Pros, 4 MPPTs, 39 Panels, and a 4 stack of HomeGrid Batteries
Settings and firmware look OK!
Equipment under warranty?"we go where power lines don't" Sierra Nevada mountain area
If I stop using Load Shave I have no issues.
Like the doc says, don't do that😉😉
Sounds like a weido, call Schneider."we go where power lines don't" Sierra Nevada mountain area
