Conext MPPT 60-150 can be used with Batt LifePo4
Ghost_PR
Ghost_PR Registered Users, Users Awaiting Email Confirmation Posts: 5
I have a Conext 60-150 with a (4)LifePo4 pro Lossigy Batts (12v 100Ah deep cycle Lithium 100A BMS) phosphate in a 24 volts system. But in the MPPT I can’t select a lithium option because in the bat option menu only appears (Gel / AGM / flooded) any suggestions to setting up correctly? Thanks in advance
  • Ghost_PR
    Any help will be appreciated
  • Dave Angelini
    Dave Angelini Solar Expert Posts: 7,103 ✭✭✭✭✭✭
    Use the custom battery menu and use open loop setpoints recommended by Battery manufacturer.
    E-mail offgridsolar@sti.net
  • Ghost_PR
    edited August 2024 #4
    Hello @Dave Angelini thanks for responding. The problem is I can’t find how change the battery type to custom 😭 any help to find the option will be appreciated. Thanks
  • chrisgraham
    chrisgraham Registered Users, Users Awaiting Email Confirmation Posts: 7 ✭✭
    What model of MPPT do you have? Does it need to be updated?
    If not, you can choose AGM type and adjust the charging parameters manually.
  • Ghost_PR
    Hello @Chris graham thanks for responding. My model is Schneider Conext MPPT 60 150. I don’t know how i can check if the version can be updated (I don’t know the process too). About the type the problem is if i select AGM the solar changer select a values by default and i don see option to change 😭. Look like i need another tool like a SCP to modify.
  • Dave Angelini
    Yea! you need the scp! Did NOT KNOW YOU DID NOT HAVE A CONTROLLER IN THE SYSTEM!  Sorry for the caps. The Store here sells them!
    You do need the exact right part number !
    https://www.solar-electric.com/xantrex-system-control-panel-scp-809-0922.html
  • Ghost_PR
    Ok I will buy one to see if an able to setup the batteries!
    thanks
  • Dave Angelini
    Can't remember as I have not used this controller over the HV model in 10 years... Look up in the manual for mppt 60 if it can go into advanced settings by pushing the 3 left buttons at once. If it can,
     you should be able to find the custom battery menu. You might need the controller for this but...
    Post here if it works and it might help someone else!
