How to determine the optimal Solar installing angle
zoijames
zoijames Registered Users, Users Awaiting Email Confirmation Posts: 1
What is the optimal angle for installing solar panels to maximize energy production in my region? is there any universal formula to get the maximum electricity and my fesco bill online
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,199 ✭✭✭✭✭
    True solar south, (in the northern hemisphere) and vertical angle set at your latitude.
    Look up th phone app called Solar Tilt. It's really cool and amazingly helpful.
    Solar Tilt - Apps on Google Play
  • DanS26
    DanS26 Solar Expert Posts: 274 ✭✭✭
    This is how I found true solar south.....
    1. Go to the NOAA site and find solar noon by time and date by using your latitude and longitude
    https://gml.noaa.gov/grad/solcalc/
    2.  Using a plum bob and a step ladder at exactly solar noon at the correct time and date find the shadow line created by the plum bob.
    3. Drive a stake or marker at the bottom and top of the shadow line at your construction site.
    4.  Walla.....true solar south.
    23.16kW Kyocera panels; 2 Fronius 7.5kW inverters; Nyle hot water; Steffes ETS; Great Lakes RO; Generac 10kW w/ATS, TED Pro & Emporia System monitoring since 2011
  • littleharbor2
    In my location true solar south is about 12 degrees off of magnetic south
  • Miller_Ranch
    Miller_Ranch Registered Users Posts: 57 ✭✭
    This is what I use to set mine four times a year.
    https://www.solarpaneltilt.com/
    It does also depend on other issues... If you have morning or evening shading, morning Marine layer, or afternoon thunderstorms, etc...
    In the end, it is probably "better" to spend for a 10-20% or larger array, than to worry too much about optimizing exact installation. For example, just changing to heavier AWG cable can change wiring losses from 3% (or greater) to 1% (typically the max $$$ cost effective copper cabling costs vs losses).
    Add that array will have losses to to aging, hot weather, dust on panels, any shading from trees or other shading sources--Just going with a larger array than you "need" is not a bad way to go.
    PVWatts has a lot of options regarding detailed solar harvesting:
    https://pvwatts.nrel.gov/pvwatts.php
  • ThirstyRoss
    ThirstyRoss Registered Users Posts: 20 ✭✭
    We just set ours to the optimum winter angle (60 degrees) and leave them there, we generate so much excess in the summer even at the winter angle that it's not worth the effort of adjusting our racking.  It's also steep enough that they shed snow fairly readily.
  • t00ls
    t00ls Solar Expert Posts: 283 ✭✭✭✭
    I set my forward tilt to middle of winter and summer and put it on a single axis tracker using some website that tells the optimum angle for solar
    there are pictures of my homemade tracker on here somewhere
    https://forum.solar-electric.com/discussion/13744/solar-tracker-finished#
    the controller came from https://www.theanalogguy.com ....ST1-10a model, the ball screw actuator is from venture manufacturing....made in the US...I think it is an 18 or 21 inch extended and ha 2 limit switches ..1 is adjustable
    the pivot is a small trailer axle
    good luck
    12 panels 6 series 2 parallel 2100 watts, 1 XW60-150 CC, 16 trojan 6V batteries 8 series 2 parallel 450 Ah, 1 XW 6848 pro, 1 5500 watt champion inverter generator( I know...I need a 12Kw )
  • oliviacarter
    oliviacarter Registered Users Posts: 2
    edited December 2025 #9
    Optimal solar installation angle mostly depends on your geographical latitude. A simple method is to set the panel tilt equal to your location’s latitude for year-round balanced output. Many users even adjust angle seasonally for extra efficiency —
    • Summer: slightly lower angle
    • Winter: slightly higher angle
    • Avoiding shading during peak hours improves results a lot
    Also, to practically measure whether angle adjustments are improving energy efficiency, keeping track of monthly consumption is very helpful. For grid users in Pakistan, online bill tracking makes comparison easier, I personally monitor usage from https://fescoebillcheck.pk/ to see the monthly change after panel tilt modifications.
    This helps evaluate ROI better rather than relying only on theoretical angle charts.
