EASUN ISolar SMK 5KW hybrid inverter connected to a DYNESS B51100 Lithium Battery
luqman
Registered Users Posts: 15 ✭✭
Hi, I had an Easun Isolar SMK 5kw hybrid inverter connected to a lead acid battery.
I have recently bought a DYNESS B51100 Lithium Battery 5KW 48V, can anyone suggest the right dip switch setting on the battery and the right setting on the Easun inverter.
If anyone also knows which inverter is similar to the Easun Isolar. Image of the inverter is provided below.
thank you.
thank you.
