Decoding Renogy 60A controller instructions HELP?
garynappi
garynappi Registered Users Posts: 120 ✭✭
edited April 2024 in Solar Beginners Corner #1
I've been trying to decipher the on/off load times of my Renogy controller without success.
My previous controllers had a dusk to dawn (or something analogous) where I could set a default or when the solar panels became exposed to the sun and started generating an output.
Toying with the "Load Parameter" settings was useless as the load came on when I didn't want them.
Does anyone know how to setup the load for something approximating dusk to dawn? I "assume" that the load will be shut off (LVD) in the event the battery falls below some dangerously low level for the battery? I "assume" because the settings do not show this as an available setting.
  • garynappi
    As a retired IBM PC development Engineering technical writer I can say with certainty the "APP" for the BT-1 (and likely for the BT-2) is maddeningly poorly worded.
    All makers of consumer devices for a particular targeted sales region REALLY need to have a regional native speaking person write or at the very least evaluate and suggest a translation of the verbiage for the app AND support documentation. Alpha and Beta test subjects is a good idea.
    Some examples...
    Record --- Last day "Should be "PREVIOUS day" Last day "implies" either "Today" or the last day recording was successful.
    Battery type = SLD?
    In the load section, the Load slide switch: "Status: Close" appears as if the load is on when in actuality it's off
    This reads better as Load: Off or Load: On
    Optionally Load Status: Off or Load Status: On.
    TEMP indicator: Is in the battery section which leads the user to believe it's the battery temp NOT the temperature of the sensor for the CC environment.
    The entire "Load Parameter" is a do over.
    I read that they are no longer updating this app which is an error in judgment as they are still selling the BT-1.
    Technical manual updates being frozen while a product is still in the retail pipeline is just plain poor management direction.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,199 ✭✭✭✭✭
    The load timers are usually triggered by darkness. I would try 12 hr. setting.
  • garynappi
    Thx, I did but the load comes on when there is still lots of daylight and they stay on well after there is light. I will give Renogy another call and hopefully they will return it.
  • littleharbor2
    Sure you don't have the load set for 24 hours?
  • garynappi
    Yup, it goes on when the panels are still at 11 volts and off when the sunlight is reasonably high.
  • garynappi
    The SRNE phone app fixed everything.
