Vertical Turbine in Brussels
WebPower
Registered Users Posts: 93 ✭✭
I was in Brussels a couple of weeks ago and saw this vertical turbine out by the NATO HQ building. It was spinning. Looks like its on the Toyota Motors compound. Its not mounted that high up. Maybe 20-30 feet to the bottom of the blades.
Just interesting to see since the general consensus is that they aren't worth the bother.
Pat
9000+W grid tied IQ7 22 panel rooftop and 6 panel ground combination with 1 additional IQ7XS connected to 500W wind turbine+200w solar+2 IQ7s with 300W+600W on the RV grid tied when it's in the driveway.
From a mechanical standpoint, the perpendicular weight of the turbine is evenly distributed over the bearing race. Would appear to have a longer bearing life vs the typical horizontal turbine design.
Probably not as efficient but the offset is longer mechanical life.23.16kW Kyocera panels; 2 Fronius 7.5kW inverters; Nyle hot water; Steffes ETS; Great Lakes RO; Generac 10kW w/ATS, TED Pro & Emporia System monitoring since 2011
