Schneider CSW 4024, ComBox gaps in Performance graphs, FTP fail - related!
Loren_Amelang
Registered Users Posts: 14 ✭✭
I have a Schneider CSW 4024 Inverter with a ComBox, from 2016.
I think I've solved this mystery, by connecting two symptoms I couldn't imagine were related.
My "Custom Log" FTP uploads stopped working last month.
And every day since about then, my Performance graphs have had gaps:
19:00 to 20:03 is a straight line in the Performance graphs
10:30 to 11:33 is a straight line in the Performance graphs
(3AM is the auto-reboot, with no obvious gap in the graphs)
The logs showed the same items every day, at the same times:
File Link: 20240117.flt.txt
Time Action Device ID Code Description
2024/01/17 20:02:15 Set ComBox N/A N/A Data Logging Stopped
2024/01/17 11:32:15 Set ComBox N/A N/A Data Logging Stopped
2024/01/17 03:07:16 Set ComBox N/A N/A Data Logging Stopped
This one from before the fail has a CLEAR:
# Conext ComBox fault log cb-B13748311 [2023/12/16 01:14:00]
2023/12/16 01:14:00,SET,0018,Data Logging Stopped
2023/12/16 09:47:32,SET,0018,Data Logging Stopped
2023/12/16 22:38:55,CLEAR,0018,Data Logging Resumed
But the FTP upload has no connection to the times when the Performance log gaps happen...
Appears it lost the FTP login password. I re-entered it, and both symptoms seem to have stopped!
Detail:
2024/01/17 20:01:49 System Startup - Application Version: Ver03.08BN0874
2024/01/17 20:01:49 Xanbus Bus Online
2024/01/17 20:01:49 Network Cable Connected
2024/01/17 19:59:59 Watchdog timeout on process LUA
2024/01/17 19:59:59 System Reboot requested by Watchdog Reboot - rebooting in 8 seconds
2024/01/17 11:32:00 Created Xanbus Device: CSW ( 1187464 )
2024/01/17 11:31:53 SNTP:OK Server Time:Wed Jan 17 11:31:52 2024 RTC Time:Wed Jan 17 11:31:53 2024
2024/01/17 11:31:49 System Startup - Application Version: Ver03.08BN0874
2024/01/17 11:31:49 Xanbus Bus Online
2024/01/17 11:31:49 Network Cable Connected
2024/01/17 11:29:58 Watchdog timeout on process LUA
2024/01/17 11:29:58 System Reboot requested by Watchdog Reboot - rebooting in 8 seconds
2024/01/17 03:07:01 Created Xanbus Device: CSW ( 1187464 )
2024/01/17 03:06:54 SNTP:OK Server Time:Wed Jan 17 03:06:53 2024 RTC Time:Wed Jan 17 03:06:54 2024
2024/01/17 03:06:51 System Startup - Application Version: Ver03.08BN0874
2024/01/17 03:06:51 Xanbus Bus Online
2024/01/17 03:06:51 Network Cable Connected
2024/01/17 03:05:00 System Reboot requested by reboot command - rebooting in 8 seconds
These "Diagnosis" items began showing up when my FTP custom logs stopped working. None in the Diagnosis history before that.
Reg[11]:[0X0]
Reg[12]:[0X0]
LR:[0X0], Exception at:[0]
WDT at:[1703059800], WDT Module Name:[]
Free[0],Used[0]
Free[110],Used[1390]
Maybe this will help someone else mystified by hour-long gaps in the Performance graphs...
Good for you! Since you are pretty new here, wanted to make sure you know that the main reason Combox was replaced with Insight is the security flaw combox users risk. I would make sure the internet is only connected to combox when getting data. Using it local is fine."we go where power lines don't" Sierra Nevada mountain area
E-mail offgridsolar@sti.net
