Schneider XW+ 6848 sell to grid confusion
rescool
Registered Users Posts: 1 ✭
I have two schneider XW+ 6848 inverters, and have sell to grid enabled on both. However, the numbers on the attached screenshot don't add up, i.e., sell to grid + load is about 1.5kW more than solar production. I know for sure the load number of 2.7kW is wrong because I turned off most of the appliances in the house, and the correct number is less than 800W, then the numbers will add up.
- Why the load number is wrong
- If I still want to sell to grid, should I do it on both inverters, or just one of them?
I got a pair of these xw 6848 pro units. Selling to grid. Can't get them over 6 kw. Each one does 3025 watts. When I look at the settings on Insight Home I see 20 amps sell max on each one. But when I try to modify that I get a red box blocking me. Only when I try 12 amps does it light up green. Doing the math the 3000 watts IS 12 amps on the AC side. What is limiting me. I used to be able to push 10 kw, now just 6 kw !!! Seems to be out of my control as in 'Grid Codes' software.hybrid: two xw6848 pro with five mppt60, 13 kw pv
17 cell Eve 280ah LiFePO4 storage 14 kw (now at 3 banks) total 40 kw
gridtie: sunny boy sma 2x 5k
Gateway / Insight Local
- 896 Solar Product Reviews & Opinions
