Off Grid EV charging dump load
jtdiesel65
Solar Expert Posts: 242 ✭✭✭
Hi,
I see NAZ has some kits for EV
charging from solar surplus and I'm was wondering if anybody has set up
the same capability for off-grid?
I'm
wondering if this can be set up the same or similar to how hot water
dump loads are setup? I can use midnite classic aux or BMS aux which
allows triggers on float state, voltage or SoC.
The
NAZ on-grid kits use clamps on L1, L2 and a smart meter that works in
conjunction with the EV charger. Anybody know if there is a similar
device setup for off-grid?
I've not yet looked over these kits. This is, however, something I'm planning to build.
Our cabin is off-grid, 24-volt bank, 16 or so 345-watt panels. I'm working on converting my 2001 Subaru Outback to a 48-volt high-performance golf cart system and will see about giving it some of the extra juice from the house solar.
Rather curious to see other setups.
