Advantages of Water-based Lithium Battery for Solar Energy Storage
Firstly, I would like to explain what’s water-based lithium battery. It’s also a kind of lithium battery, which uses water-based binder to replace PVDF as the binder of positive active substance. Compared with PVDF, it is safer and more environmentally friendly, because the water-soluble electrode does not contain nickel, cobalt and PVDF, then the manufacturing, use and recycling process are all green and environmentally friendly.
And the negative active material adopts nano carbon fiber and artificial graphite, so that the battery always keeps the inherent molecular structure unchanged when receiving high current charging. It is characterized by impact resistance, high safety, wide temperature resistance and long life.
Therefore, it has the following advantages for solar energy storage,
1. High level of safety, high temperature resistance and never explode.
2. Long cycle life with more than 7000 times.
3. Low self-discharge rate, less than 1% per month.
4. Environmentally friendly without nickel, cobalt, PVDF.
5. Wide applicable temperature from -45C to 85C.
If you guys have other opinions about this topic, pls feel free to leave your comments.
