Magnum 4448 failure
oglethorp
Solar Expert Posts: 30 ✭✭
I have a failed Magnum 4448 on a Midnite solar E-panel ? is,, What other Inverter/Charger will mount on the same E-Pannel with comparable power outputs???
You could look around on this MN Products Page:
https://midnitesolar.com/products.php?menuItem=products&productCat_ID=52
The following Manual gives a fairly good idea of some inverters, as mounted to E-Panels, might give some ideas, assume that you will want an Inverter/Charger:
https://www.midnitesolar.com/pdfs/10-003-1_REV_J_E-Panel_Manual.pd
AND/OR, ask on the MN Forum, in this Topic:
https://midniteftp.com/forum/index.php?board=4.0
Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
