Can Two Separate Solar Systems Combine in One Panel ?
Lysdexicuss
Registered Users Posts: 12 ✭✭
Newbie, trying to create 240 to power Water-Heater along with four to five 20 amp circuits
First array = Six 100 watt panels, Aims 80 amp MPPT, Aims 3500 watt inverter, 200 ah lifepo4
Second array = Two 200 watt panels, Renogy 40 amp MPPT, Renogy 2000 watt inverter, 200 ah lifepo4
Combining everything in a 125 amp Seimens Panel, the 120v feeds from each inverter to separate phases, bonding all the grounds, isolating neutrals on separate neutrals bars...
Will this work to create 240v for double-pole breakers or will there be a conflict with these separate systems ?
Thanx in advance
Thanx in advance
Any two random 120VAC inverters not designed to work together won't be able to make 240VAC because they won't be in sync (they'll effectively fight each other).
Have you thought about swapping out the 240V heating elements in your tank for 120 VAC heating elements instead? Many electrical hot water heaters have two independent heating elements anyways. If each have their own thermostat you could deliver all of the power of your inverters but would have to wire them individually to each element.
It would probably be best to use two separate panels though to have breakers and all done right. Not sure if this could be done under code. Maybe make the 600 watt array feed one 120 V element.
Hopefully these are not 12 V inverters because hot water heating plus 20 amp circuits seems like a pretty significant load.Offgrid in cloudy PNW
Full Schneider system with 18 REC 420W panels, 100A-600V controller, XWPro, Insight Home, six Discover AES Rackmount 5kW batteries (with integrated heating), Slimline enclosure, Lynk II, AGS, H650, H2200, H3000 (Propane conversion on Victron AutoTrans with Gen Line 2 wire AGS on AC1), Kubota 4500, Onan 7500 (on second AGS and AC2).
Thanx Graham i like your idea of 120 V water-heater alteration, will look into it. Both inverters are 12v, as are the panels etc.
Will upgrade some day to 24v system
