Wire
jACKr
Registered Users Posts: 16 ✭✭
Aloha!
Back about 20 + years ago, wire for PV panels was a different requirement? 6 gauge was the normal.
And, it wired directly to back of panel.
Now I see 10 gauge on much higher output panels.
Has anyone had to downsize to accommodate the newer technology ? What problems would larger gauge experience, if any?
Mahalo!
jACKr
Mahalo!
jACKr
Back before MPPT controllers and when 12 volt systems were the norm we were sending high current / low voltage power off the roof from parallel wired array's. Now we can wire all our panels into a single, high voltage / low current string and send it to our MPPT controllers on small gauge wire . There's really no problem using oversized wire between the PV array and Controller or Combiner box as long as it fits into the connectors.
