Will ComBox pass Modbus data to the new XW6848 Pro
tampasolar
tampasolar Registered Users Posts: 84 ✭✭
Have Schneider Electric XW6848 Pro
Out of the box requires the interface called Gateway for comm paths to the world and upgrades
Have a ComBox that won't work with XW6848 Pro -- that's my experience and what I'm told now.
Now discovering the Modbus and tcp port 502 thru LAN data path(s).
Curious question is:  Since I can talk to ComBox with Modbus, can the Modbus get pushed to an XW6848 inverter ?
Big question.
hybrid: two xw6848 pro with four mppt60, 12 kw pv
17 cell 280ah LiFePO4 storage  14 kw (now at 3 banks) total 40 kw
gridtie: sunny boy sma 2x 5k
gridtie: fronius ag5100 two 5k (only one with 1.5k left) running on fumes
Gateway / Insight Local
  • Dave Angelini
    Dave Angelini Solar Expert Posts: 7,078 ✭✭✭✭✭✭
    Depends on what you will do with XWP? Some things will work and somethings may have unspecified results. In other words it would be risky to do modbus with combox. Very risky for Offgrid but if you have the grid, it is your dime! For a little over $300 you could get the Insight home and do things the right way.  Good Luck!
    XW pro has always stated that the Conext Gateway Home model or Gateway Facility is required. Combox has been out of support for at least 3 years now.
    • XW Pro 120/240V – 865-6848-21
    Note: Please note that InsightHome or InsightFacility is required to commission the XW Pro.
    Note: XW Pro is not compatible with Conext ComBox. InsightHome and InsightFacility Edge Devices is used for the monitoring, commission, and configuration of the XW Pro.
    E-mail offgridsolar@sti.net
  • tampasolar
    Anybody here have a ModBus Map aka table for the structure for the ComBox generation ?
  • Dave Angelini
    Schneider still has all info and data on their website for discontinued products.
    One of the top 3 reasons combox was discontinued is
    Security Notification – Schneider Electric is aware of a vulnerability in its Conext™ ComBox product. Please read this document for further information. Due to product limitations a firmware update will not be provided. We strongly recommend customers to consider upgrading to InsightHome or InsightFacility.
    Use the link below and you will find the maps under technical publications. Hurricane headed your way?
    https://solar.se.com/us/en/product/conext-combox/
