Electric fence solar panel to charge battery
petertearai
Solar Expert Posts: 471 ✭✭✭✭
Hi . Im looking to provide solar to keep a 12 volt fence energiser running .the specs for the energiser say average 8 watts . At 12 volts that is .66 amps . Times that by 24 hours and we have 15.84 AH . 2 days autonamy and we have 32AH.
The manufacurer recomends their 80 watt kit . And a 100 AH battety .
A 100 ah batery sounds right . But 80 watt pannel sounds too small .
Any sugestions ?
Any sugestions ?
2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
Starting with the math for a "conservative" system:
- 8 Watts * 24 hours per day load = 192 WH per day
- 192 WH per day * 2 days "no sun" * 1/0.50 max planned discharge * 1/12 volt battery = 64 AH @ 12 volt battery (FLA)
Charging at "non-winter" 5% to full time off grid 10-13% rate of charge:- 100 AH * 14.5 volts charging * 1/0.77 panel+controller deratings * 0.05 rate of charge = 94 Watt array minimum
- 100 AH * 14.5 volts charging * 1/0.77 panel+controller deratings * 0.10 rate of charge = 188 Watt array nominal
- 100 AH * 14.5 volts charging * 1/0.77 panel+controller deratings * 0.13 rate of charge = 245 Watt array "typical" cost effective maximum
And based on hours of sun per day. Assuming fixed array around Auckland New Zealand, facing north:
http://www.solarelectricityhandbook.com/solar-irradiance.htmlAuckland
Measured in kWh/m2/day onto a solar panel set at a 38° angle from vertical:
(Optimal winter settings)
Using June as "break even" winter harvest:Jan Feb Mar Apr May Jun 5.07
5.03
4.87
4.30
3.64
3.36
Jul Aug Sep Oct Nov Dec 3.60
3.91
4.52
4.56
4.79
4.83
- 192 WH per day load * 1/0.61 DC off grid system eff * 1/3.36 hours of sun per day (June) = 94 Watt array "June break even"
- 94 Watt June break even array * 1/0.50 base load fudge factor = 188 Watt array
If you run the system only spring and summer (growing season, keep the sheep out of the garden)--You could flatten the panels out a bit to better catch spring/summer/fall sunlight and get away with a bit less solar panel:Auckland
Measured in kWh/m2/day onto a solar panel set at a 53° angle from vertical:
But--Your marine layer/amount of sun does not increase that much during the summer--A larger panel/array will still give you some better peace of mind.Jan Feb Mar Apr May Jun 5.80
5.54
5.10
4.27
3.47
3.14
Jul Aug Sep Oct Nov Dec 3.39
3.82
4.63
4.92
5.41
5.57
Your thoughts/corrections?
Which fence charger is it?
I'm running a 3.1-joule Parmak U012 and a Group-27DC 109aH Wallyworld. The 27DC will keep my 1/4 mile of polywire HOT for 30 days without charging...another 15-20 days before I would charge it. The support guy at Parmak told me that the U012 uses about one amp a day. I tend to agree with that in respect to the length of time it will run without charging the battery. I *just* set it up on solar maybe two weeks ago. I connected a little 12 or 14 inch square surplus panel that I bought many years ago and that had been sitting in a shed ever since then. On a good day it puts out about one amp. The battery status light shines strong.. Bill,@BB. , here on NAWS, gave me some feedback and info on some questions I had about the battery staying charged "too good" and a good bit of other things.
Here's a link to that thread: https://forum.solar-electric.com/discussion/357190/mammoth-015kw-pv-system#latest
I'm using a waterproof solar charge controller that I got off of Amazon. It seems to be working great, thoughI haven't tried anything on the load circuit, yet. The only thing I'm not thrilled about is the really, really, *really* bright green state-of-charge indicator LED...I'm thinking of lightly painting over it to subdue it a bit...as it is now I can tell from my computer chair at the house whether the battery is charged up or not...200-feet away, roughly...but, I think I could see it if I flew over at about 10,000-feet, too!<grin>. Here's the link for the controller: https://www.amazon.com/dp/B07CK2PCC7?psc=1&ref=ppx_yo2_dt_b_product_details
Wow bill . Thanks for your in depth analysis. You are right . Near auckland . It will run 24 7 . All year round . So will err on the larger size.
Thanks again for the the time you spend with your clear workings . Much appreciated .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home -
Hi it is a Gallagher mbs1000iIntheswamp said:Which fence charger is it?
A reasonable sise unit good for 100 acres . Can't remember how many kilometers of fence . It needs to be pretty good to keep occasionally grumpy cows and bulls on the correct side of the fence , and save fence damage .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home -
petertearai , that looks like a Cadillac
7.7 joules should turn most anything on its tail that pushes against it! It looks to have roughly the same amount of fencing length as my Parmak does...around 30 miles of clear fence...?? After looking at the specs I would probably consider going with a couple of Trojan T-105 6-volt golf-cart batteries (or your equivalent) for a few more days of backup power and longer term durability. Looking at your signature line I see you are well-versed in solar energy, apparently, so I'll keep my other newbie thoughts to myself.
Just thought I'd share the thought on storage capacity.
