Do you have a POWER STAR 3KW inverter?
Fingers
Registered Users Posts: 19 ✭✭
This is a 24volt 3000watt continuous - 6000 peak inverter, 230-240volt (no split voltage).
It is pretty much is what it says on the tin (however it's self power use at rest is 100 to 150watts).
Do you have one?
Have you had it running a washing machine?
Washing machine 8.1amps x 230volts = 1863watts, so loads of room for spikes if the washing machine is it's only job...... Right?
Thank you for your input
