Solar Panel Angle
Wallace
Registered Users, Users Awaiting Email Confirmation Posts: 1 ✭
Welcome to the forum Wallace,
The overall most harvest of energy over the year would be you latitude of 51 degrees from horizontal.
If you want more energy during summer, then roughly 51-15=36 degrees.
If you want more energy during winter, then roughly 51+15=66 degrees.
You can use a solar calculator to estimate the best angle based on your location and local weather conditions... Here are two. The first is a simple program. The second a bit more complex:
http://www.solarelectricityhandbook.com/solar-irradiance.htmlWinnipeg
Measured in kWh/m2/day onto a solar panel set at a 40° angle from vertical (or 50 degrees from horizontal):
This is also used as "hours of sun" per day. >3 hours of sun per day is "useful" amount of solar... Less than that, not a lot of sun and you need more panels make up for the poor sun.Jan Feb Mar Apr May Jun 2.24
3.37
4.40
5.08
5.13
5.05
Jul Aug Sep Oct Nov Dec 5.27
5.04
4.09
3.26
2.47
1.87
Same place with winter angle--Note that "winter angle" does not really help much (other than shedding snow). And if you have trees or hills, that also makes winter harvest more difficult:Winnipeg
Measured in kWh/m2/day onto a solar panel set at a 25° angle (from horizontal--Or 65 degrees from vertical):
(Optimal winter settings)
For locations with lots of snow--A more vertical panel angle sheds snow better--Or at least easier to clean (snow on panels, basically zero harvest until snow is cleared.Jan Feb Mar Apr May Jun 2.31
3.39
4.24
4.65
4.51
4.42
Jul Aug Sep Oct Nov Dec 4.57
4.53
3.87
3.24
2.54
1.95
A more complex calculator--And allows you to more exactly match your location, use one or two axis tracking, etc.:
https://pvwatts.nrel.gov/pvwatts.php
Thank you Bill.
