Inverter / Generator help
NovosEnergy
Registered Users Posts: 2 ✭
Hey friends….Hoping for some guidance with Generac guardian series generator working with SolarEdge EnergyHub inverter and BUI / ATS.
SolarEdge doesn’t support control of the Generac through the BUI like they initially told us. Now we’ve got a few installed; SolarEdge tells us we need a firmware update, but they have no timeline on its launch. We are getting zero help from SolarEdge.
Does anyone have advice on how we get the generator working as a backup power source and how is the gen wired in to the BUI (with schematics if possible). Advice? Or something that would work?
are you trying to set up auto start?
I am doing the same thing. Solaredge BUI with a Generac Guardian 16KV. Anyone had success wiring this? I am assuming the relay contacts will provide the autostart, but don't want to burn something up by simulating contact closure and shorting.
