Battery Absorbtion time with solar + wind
MatthewLynch
Registered Users Posts: 3 ✭
Hello, I currently have a solar instalation for aon off-grid micro grid. I have 12kW in solar panels and 1200Ah 48V battery bank. I also live in a very windy place (average wind is 9 m/s) so I have been considering a wind turbine to reduce the ammount of cycles or DOD on the batteries during the night or winter when we have very short days.
My concern is that all wind turbines I could find in my country they use a divert load to regulate. So when batteries reach a specified voltage it will dump the rest of the load. In summer days are very long and I will fully charge the batteries almost every day. The people selling the wind turbine said I should set the divert voltage slightly higher than the absorb voltage of the solar charger. So for my batteries (VRLA) the manual says 2.35V per cell with a -4mV/°C compensation. So for example the divert load would be set to 2.38V per cell. My concern is hoy much time the battery would be at this voltage. Currently my solar charger will do a 3hs absorb and switch to float. But taking into consideration in summer we have alot of sun and also alot of wind I don't want to damage our battery bank by having it at absorv voltage for several hours a day.
Will this damage the battery? or what should I do?
Welcome to the forum Matthew,
I am guessing you are somewhere in Argentina?
It sounds like you have a good idea of how to setup and run the wind charging in combination with the solar charging system.
Most basic wind charging systems work as you suggest... Wind turbine connected directly to battery bank with some sort of dump controller... Horizontal Axis Wind Turbines will over-speed in moderate to high winds (and can self destruct) without a load (battery bank) attached.
There are integrated controllers of various types that can shutdown the turbine when the battery is full (brake, furl, feather, or "short" the turbine's alternator to load and "stall" the blades).
I see you have posted a link to a DIY (do it yourself) dump controller in another thread in the forum:
https://gitlab.com/TiEoLibre/Analog_Battery_Regulator
If you are looking to install wind on your property... Building your own turbine can be better than many you can purchase...
9 m/s (20 mph) wind speed is very high/good... Is that "average" or peak for your area. Most turbines seem to need around 10-12 MPH to begin to harvest a "useful" amount of power, and >25 MPH many will start to reduce harvest or even shut down for safety.
Turbines usually need around a 10-30+ meter tall tower to get into "clean air" (need to be above trees/buildings in area)...
Midnite Solar makes some "interesting" systems for wind turbines. They uses their MPPT type charge controller to optimize energy harvest from turbines (MPPT allows the turbine to turn at "optimum" RPM based on wind and energy needs--MPPT can dramatically wind harvest--And integrated dump controller:
https://www.solar-electric.com/miso4wadctuc.html
http://www.midnitesolar.com/products.php?menuItem=products&productCat_ID=25&productCatName=Wind and Hydro
I don't know much about these systems... So others will have to supply that information (or contact the mfg/supplier).
Do you have some hardware you are thinking of using/buying/building?
Hi Bill, I had forgotten the name of the forum and have been looking for it ever since. That is correct, I am in Argentina and in a very windy area. All publications say average wind speed is around 9m/s, but I am not quite sure about it, I think it will probably be between 7 and 8 m/s. But we do get much higher average winds sometimes. Here is a photo of this last week
I have been considering building my own turbien for quite some time. I would also like to develop a DIY universal MPPT charge controller with dump load for wind turbines. But where I am at the moment I can't do that and the location where I would like to put the wind turbine I am only there for about a month a year. So since I don't have experience building I don't what to leave my family with a defective turbine till I am there and can check it again. Or have it charge wrong and damage the battery bank.
So for the moment I am considering purchasing one till I can have a place to work on building and test one. I have been suggested to check Aeolos wind turbines, they seem to be good. Do you know anything about Aeolos turbines? I would like a 3kW horizontal turbine.
Matthew -
I don't have any information on Aeolos turbines--And I will have to leave it to others here to comment on their turbines/systems.
Are there any of their products installed in your area? Can you get daily Watt*Hour/Amp*Hour harvest numbers? If you can get >1 year of data--That is a good start (many turbines from other manufactures don't even last 1 year before major failures... And some don't even work out of the box).
Our forum does not have much traffic in the way of Wind--Some "wind links" below:
For DIY wind turbines (and other Wind related stuff):
http://scoraigwind.com/axialplans/index.htm
https://www.windstuffnow.com/main/ (smaller turbines)
Wind Power Links
www.otherpower.com (good forum for DIY Wind Power)
Hugh Piggott - Scoraig Wind Electric site for tons of info (from mike90045)
Scoraig Wind "Recipe Book" for DYI Turbines (from Chris Olson... From his 4/11/2013 post)
www.greenpowertalk.org (added from "russ"--Like here but more wind/less solar)
Small windpower a scam ? Survey says SO
Truth About Skystream & SWWP
Windmax HY-2000 2kW Wind Turbine (apparently, some vendors don't sell spare parts--just new turbines. However, the owner, Edward has been very happy with its performance from 2010-2012--BB. 5/31/2012)
