MPPT solar controller
If we use 120W power panel, 16.9 V and 7.1A . our battery condition is 10.5 V than how much the controller produce current. Is this formula held good. 120=A x 10.5, that is A=11.42
Re: MPPT solar controller
The formula is correct, but I don't think that you will see that much MPPT gain in the real world. With low batteries, AND low PV temps, you might see 15-20% increase,,, less as the battery gets higher, and the panel temps increase.
In my system,, with battery voltage ~12.4volts, and cold morning temps,, I see about a 15% increase.
Tony -
depending on the amount of sun you are seeing you will probably get up to 7.1a unless you are using an mppt controller and under the circumstance of being 100% depleted it could deliver around 20-30% more current give or take. 10.5v is a dead battery and is 100% dod, not to be confused with doa, but keep draining it that far and it soon will be.
