Sub-Metering 8 separate buildings in a Victron ESS
richardimorse
Registered Users Posts: 98 ✭✭
System is a 90kW (6 15kW Quatros) What is the best way to do this, I could install 8 * Carlo Gavazzi Meter EM24 Ethernet in the 3-phase distribution board which takes the 120mm cable from the transformer/generator and splits it into 16mm armoured cable for each building
The meters can be manually read, then am I correct in thinking that I can use the Carlo Gavazzi software to look online at each of the meters which use Modbus/TCP Ethernet, this will give me my analysis from a management perspective
Am I also correct that the Cerbo GX will show the 8 meters separately and aggregate their power readings as the Grid Input on the graphic display, is there a limit on how many Grid meters you can have
