Frombergsa: Sizing solar array to battery bank size
Posts: 93 admin
This discussion was created from comments split from: How Many 12v Solar Panels Needed To Charge 24v Battery?.
I am in kinda the same boat. I have 24 - 2v 320ah batteries (that is not a typo - its is correct).
I am looking at building 2 - 24v systems as it appears to be the most efficient. How do I figure out how many panels I need to charge the batteries? -
Formbergsa, welcome to the forum.
I have split this to your own thread/discussion. That way we can focus the Q&A on your needs and system and not get confused about other folk's systems.
Personally, I highly suggest that a system be designed to support your loads. Pick your most efficient devices, size the battery bank for those devices. Then size the solar array to support the battery bank charging needs, and your loads (based on your daily usage, hours of sun per day, seasonal needs--Summer cabin vs full time off grid).
I will go through a very quick set of math here--Just to give you an idea of the process... But please ask questions and tell us more about your needs.1
Since we are starting with a battery bank--Nominally, a good design is for the bank to support 2 days of "bad weather", and 50% maximum discharge (this is for a flooded cell lead acid deep cycle battery bank--But close enough for many other Off Grid cabin/home designs. For RV/Campers/etc. need more discussion).- 320 AH * 24 volts * 0.85 AC inverter eff * 1/2 days storage * 0.50 max discharge (longer battery life) = 1,632 WH per day from battery bank
- 320 AH * 29.0 Volts charging * 1/0.77 panel+controller derartings * 0.05 rate of charge = 603 Watt array minimum
- 320 AH * 29.0 Volts charging * 1/0.77 panel+controller derartings * 0.10 rate of charge = 1,205 Watt array nominal
- 320 AH * 29.0 Volts charging * 1/0.77 panel+controller derartings * 0.13 rate of charge = 1,567 Watt array "typical" cost effective maximum
http://www.solarelectricityhandbook.com/solar-irradiance.htmlBurnaby
Measured in kWh/m2/day onto a solar panel set at a 41° angle from Vertical:
Toss the bottom three months (not much sun in winter, assume either not used or backup genset and lots of fuel):Jan Feb Mar Apr May Jun 1.89
3.05
3.86
4.77
4.94
4.90
Jul Aug Sep Oct Nov Dec 5.32
5.18
4.72
3.06
2.12
1.65
- 1,632 Watt*Hours per day * 1/0.52 off grid system eff * 1/3.05 hours of sun per day (February) = 1,029 Watt array for February "break even" harvest
There is the math... You could justify an array from 603 Watts (summer weekend usage) to 1,567+ Watt array, with at least 1,205 Watts minimum recommended for a full time off grid system.
Your thoughts?
